F5 rebooting continuously-need help
We have powered up a Big-IP 2000 - 113 platform device in our DC. Assigned the management IP and route, licensed and provisioned it - assumed that we are good proceed further. But then, it started rebooting.. Its rebooting once in every 10 - 15 minutes. I have no clue why a box behaving so weird.
Most of the times, this logs were repeating..
Aug 10 05:07:03 F5-LTM1 notice overdog[5658]: 01140104:5: Watchdog touch disabled.
Aug 10 05:07:03 F5-LTM1 info overdog[5658]: 01140101:6: Overdog daemon shutdown.
Here is the logs I could find on the device. (I have removed few unwanted logs)
Aug 10 05:07:02 F5-LTM1 notice chmand[6126]: 012a0005:5: Setting netboot 0
Aug 10 05:07:02 F5-LTM1 notice chmand[6126]: 012a0005:5: Resetting host (init 6)
Aug 10 05:07:03 F5-LTM1 notice mcpd[6655]: 01070410:5: Removed subscription with subscriber id %promptstatusd
Aug 10 05:07:04 F5-LTM1 notice logger: /bin/bash /etc/rc6.d/K03bigstart stop ==> /usr/bin/bigstart stop
Aug 10 05:07:06 F5-LTM1 notice alertd[6960]: 01100043:5: logcheck Notice: Disconnect mcpd 0
Aug 10 05:07:06 F5-LTM1 warning alertd[6960]: 01100002:4: alertd is going down.
Aug 10 05:07:06 F5-LTM1 notice mcpd[6655]: 01070410:5: Removed subscription with subscriber id BIGD_Subscriber
Aug 10 05:07:06 F5-LTM1 notice scriptd[6118]: 014f0002:5: exiting
Aug 10 05:07:07 F5-LTM1 notice mcpd[6655]: 01070410:5: Per-invocation log rate exceeded; throttling.
Aug 10 05:07:07 F5-LTM1 notice pfmand[5757]: 01660000:5: shutdown cleanly
Aug 10 05:07:07 F5-LTM1 notice mcpd[6655]: 01070406:5: Per-invocation log rate exceeded; throttling.
Aug 10 05:07:07 F5-LTM1 notice sod[7229]: 010c0050:5: Sod requests links down.
Aug 10 05:07:07 F5-LTM1 notice evrouted[6959]: 01690000:5: shutdown cleanly
Aug 10 05:07:37 F5-LTM1 warning chmand[6126]: 012a0004:4: getLopReg exception: client socket select failed [lopd addr:/var/run/lopdsvr] [client addr:/var/run/hwctl.hal.sock] (errno:4) Interrupted system call
Aug 10 05:07:37 F5-LTM1 err chmand[6126]: 012a0003:3: GET_MEDIA failure (status=0xffffffff) page=0x%1 reg=0x0 : File mgmtif/BourneMgmtIfSvc.cpp Line 357
Aug 10 05:07:37 F5-LTM1 notice mcpd[6655]: 01070406:5: Removed publication with publisher id chmand_publisher
Aug 10 05:10:04 F5-LTM1 info mprov:8133:: 'Provisioning (legacy update) successful.'
Aug 10 05:10:05 F5-LTM1 notice sod[7234]: 010c0044:5: Command: running disable zrd bigstart.
Aug 10 05:10:05 F5-LTM1 notice logger: /usr/bin/tmipsecd --tmmcount 4 ==> /usr/bin/bigstart stop racoon
Aug 10 05:10:08 F5-LTM1 notice sod[7234]: 01140029:5: HA proc_running tmm fails action is go offline and down links.
Aug 10 05:59:02 F5-LTM1 notice overdog[5659]: 01140104:5: Watchdog touch disabled.
Aug 10 05:59:02 F5-LTM1 info overdog[5659]: 01140101:6: Overdog daemon shutdown.
Aug 10 05:59:02 F5-LTM1 notice mcpd[6655]: 01070410:5: Removed subscription with subscriber id %promptstatusd
Aug 10 05:59:03 F5-LTM1 notice logger: /bin/bash /etc/rc6.d/K03bigstart stop ==> /usr/bin/bigstart stop
Aug 10 05:59:06 F5-LTM1 notice mcpd[6655]: 01070410:5: Per-invocation log rate exceeded; throttling.
Aug 10 05:59:06 F5-LTM1 notice scriptd[6124]: 014f0002:5: exiting
Aug 10 06:16:29 F5-LTM1 notice logger: /usr/bin/tmipsecd --tmmcount 4 ==> /usr/bin/bigstart start racoon
Aug 10 06:24:00 F5-LTM1 notice overdog[5659]: 01140029:5: HA software_update lind fails action is reboot.
Aug 10 06:24:00 F5-LTM1 emerg overdog[5659]: 01140043:0: Ha feature software_update reboot requested.
Aug 10 06:24:00 F5-LTM1 crit overdog[5659]: 01140102:2: Overdog daemon requests reboot.
Aug 10 06:24:00 F5-LTM1 notice overdog[5659]: 01140104:5: Watchdog touch disabled.
Aug 10 06:24:00 F5-LTM1 notice sod[7243]: 010c0044:5: Command: go standby overdog.
Aug 10 06:24:01 F5-LTM1 notice chmand[6150]: 012a0005:5: Setting netboot 0
Aug 10 06:24:01 F5-LTM1 notice chmand[6150]: 012a0005:5: Resetting host (init 6)
Aug 10 06:24:08 F5-LTM1 notice logger: /bin/bash /etc/rc6.d/K03bigstart stop ==> /usr/bin/bigstart stop
Aug 10 06:24:10 F5-LTM1 notice alertd[6978]: 01100043:5: logcheck Notice: Disconnect mcpd 0
Aug 10 06:24:10 F5-LTM1 warning alertd[6978]: 01100002:4: alertd is going down.
Could some help in identifying the issue please.
- Vijay_E
Cirrus
Try doing a full box reboot. Are you seeing any error message on the F5 front panel ? You are better off opening up a case for quicker resolution.
is this a cluster? it seems to indicate that HA is seeing issues and restart because it is configured as such.
- F5Drive_266268
if it is HA then bring down the HA link and try to reboot the system in stand alone mode.
