Leo_377929's avatar
Leo_377929
Nov 27, 2018
F5 Power LED Yellow
F5 Power 1 LED turned yellow and Power 2 LED is green. Is the Power 1 module completely down which needed to be replaced or is there any other solution or reason?
  • can you check the power status one more time & provide the output of following command
    tmsh show sys hardware
  • Please provide output of tmsh show /sys hardware. We faced multiple power supply issues and we ended up replacing them. Power supply is a hot swappable.
  • Pretty old post, but still for future references & for the OP,
    There will be 4 LED indicators in the front panel,
    1. Status
    2. Alarm
    3. Power 1
    4. Power 2
    With regards to Power, there are 3 states.
    Green solid
    - Power supply is present and operating properly. Also indicates when the system in is power standby mode.
    Yellow solid
    - Power supply is present, but not operating properly.
    Off/none
    - No power supply present.
