Sumanta_88744
Cirrus
Feb 18, 2015F5 OID for CPU, memory and virtual server connection
Hi Experts
Can anyone share the F5 OIDs for virtual server, CPU usage and memory usage? This is for VIPRION 2250 blades running 11.5.1 TMOS.
Could not find any SOL for specific OIDs.
- JG
Cumulonimbus
You can download the MIBs files from your local device: Login -> click on the "F5" icon -> In the section of "Downloads", there is "SNMP MIBs" download links.
- JG
Cumulonimbus
- StephanManthey
Nacreous
Hi Sumanta,
OIDs are build dynamically. Jie already provided a link to a resource indicating the meaning of the specific counters. To dump the specific OIDs (referenced in solution) in numeric form you can run the following:snmptranslate -On F5-BIGIP-SYSTEM-MIB::sysMultiHostCpuUser | awk '{print "snmpwalk -v 2c -c public -On localhost", $1}' | bash -x | awk '{print "snmpget -c public localhost", $1}' | bash -xThanks, Stephan
- SushilKolekarF5Historic F5 Account
Hi ,
download MIB browser and export MIB for respective devices which you want check for performance for Load balancer check for Local for System please check for System for GTM Global
