F5 Not Synching after HA configuration
We currently have an F5 that was configured for sync-failover high availability. One device shows active and the other shows pending. When i go to device and overview and sync device a to group, it spins as if it is syncing and then shows awaiting initial sync with changes pending. I have tried to sync multiple times and still get the same message, is there something I'm missing?
- Joseph_Johnson_
Both devices are running version 11.x I would refer the following article and try to troubleshoot. https://support.f5.com/kb/en-us/solutions/public/13000/900/sol13946.html?sr=43152862
Do you see any message on ltm logs ? Are ntp configured and working fine ?
check date and time on both devices
dateCheck ntp
ntpq -pn- Joseph_Johnson_
Issue ended up being one box was a version behind. I updated HF and was able to finish sync.
