Mattews's avatar
Mattews
Icon for Cirrus rankCirrus
Jan 21, 2019
F5 monitoring THRESHOLD
Hi to all,
i need to know which are the reference thresholds for the parameters concerning monitoring, which are the advisable values ​​for CPU, connections, TPS, memory, throughput? Which are the values ​​that do not have to be exceeded ?
Thanks in advance
  • For CPU and Fan speed: Database variable Default value Value range platform.cpu.temperature.threshold75 degrees Celsius0 to 65535 degrees Celsius platform.cpu.fanspeed.threshold 3000 RPM 0 to 65535 RPM inclusive
    And for TMM memory configure between 70 to 80%
    Explanation about TMM memory thershold: TMM will start close connection when reaches 85%, and stop new connections when it reached 95%. TMM would not use more than is allocated to it, so would not use the swap memory. You can configure any value between 70 to 80 for your threshold.
    Thershold values to monitor are mentioned below: CPU: 75% Memory:70 to 80% Fans speed: 3000RPM
