Stan_Hurton_111's avatar
Stan_Hurton_111
10 years ago
F5 Management Pack for SCOM - Failure during discovery
We are using MP v3.2.2 on SCOM2012 R2
In a previous install it was working fine, but after a reinstall I'm getting Execute device discovery : Failure
Here's an excerpt from the log:
at F5Networks.ManagementPack.Discovery.DiscoveryManager._AsyncFinishDiscovery(AsyncDiscoveryInfo asyncInfo)Attempt to connect to the iControl device socket:Success Attempt to connect to the iControl device socket:Success Retrieve device information:Success Verify device is supported:Success Retrieve minimum supported device version:Success Calculate clock skew:Success Retrieve device management address:Success Validate unique device management address:Success Checking license expiration:Success Retrieve device self address:Success Checking if device is virtual machine:Success Retrieve device failover info:Success Retrieve device features:Success Create persisted iQuery connection:Success Retrieve Big3d Version:Success Disconnecting existing Big3d connections:Success Recreate the iQuery connection with updated Big3d:Success Attempt to connect to the iControl device socket:Success Retrieve device information:Success Verify device is supported:Success Retrieve minimum supported device version:Success Calculate clock skew:Success Retrieve device management address:Success Validate unique device management address:Success Checking license expiration:Success Retrieve device self address:Success Create persisted iQuery connection:Success Retrieve Big3d Version:Success Store device Configuration:Failure Failure Message: F5Networks.ManagementPack.Discovery.DiscoveryException: Error:Trunk100Invalid Configuration Data XML Error=Unexpected Xml tag: CDATA RawXml= Trunk100 at F5Networks.ManagementPack.Discovery.DiscoveryManager.DiscoverDevice._RetrieveDeviceConfiguration(String section) at F5Networks.ManagementPack.Discovery.DiscoveryManager.DiscoverDevice.<>c__DisplayClass2b.<>c__DisplayClass2e.<_StoreDeviceConfiguration>b__26() at F5Networks.ProgressTracking.ProgressEventSourceBase`1.<>c__DisplayClass6.b__5()
Does anyone have any suggestions or ideas as to what the issue may be?
