Tomik1_112749's avatar
Tomik1_112749
Sep 19, 2013
F5 LTM VE and CMP (Clustered Multi-processing)
I have tried to activate CMP in F5 LTM VE with max 4 cores and 12G of memory. The system does not allocate memory to other 3 cores, only to one TMM/core? tested with versions 11.4.1 (608.0) and 11.4.0 (2419.0). What am I doing wrong here?
show /sys tmm-info:
Sys::TMM: 0.0
Global
   TMM Process Id       8579
   Running TMM Id          0
   TMM Count               1
   CPU Id                  0
Memory (bytes)
   Available            6.3G
   Used               227.5M
CPU Usage Ratio (%)
   Last 5 Seconds          1
   Last 1 Minute           1
   Last 5 Minutes          1
Sys::TMM: 0.1
Global
   TMM Process Id     8579
   Running TMM Id        1
   TMM Count             1
   CPU Id                1
Memory (bytes)
   Available             0
   Used                  0
CPU Usage Ratio (%)
   Last 5 Seconds        1
   Last 1 Minute         1
   Last 5 Minutes        1
  • JG's avatar
    JG
    Could it be that it only shows the memory allocated to the process, and not down to the threads?
  • to be sure i would open a ticket with support, personally im not quite sure if VE supports CMP.
