F5 LTM Monitor
Hello Experts,
I have this configuration written in a Cisco ACE config. I want to convert this to F5 config. Can anyone please help me to write the F5 equivalent config?
probe https ACE_PROBE
port 8447
faildetect 2
ssl version all
request method get url /path/file.html
expect status 200 200
- Andy_McGrath
Cumulonimbus
Taking it ine by line:
port 8447The port 8447 is only needed as part of the monitor if the pool member is not using port 8447, else you can ignore it.
faildetect 2Cisco ACE probes uses a failure count but the F5 uses a timeout, so to get the same you need to set a monitor interval of 15 (the Cisco ACE default for http probes) and a timeout of 31 (2 x interval + 1)
ssl version allUse the default HTTPS monitor cipersuite configuration
request method get url /path/file.htmlThe request (send) will be a HTTP 1.0 request from the ACE so you can use the following on the F5
GET /path/file.html HTTP/1.0finally
expect status 200 200In the receive of the monitor configure you are looking for the status response of 200 OK
200 okComplete monitor config:
ltm monitor https /Common/ACE_PROBE { adaptive disabled cipherlist DEFAULT:+SHA:+3DES:+kEDH compatibility enabled defaults-from /Common/https destination *:* interval 15 ip-dscp 0 recv "200 ok" send "GET /path/file.html HTTP/1.0" time-until-up 0 timeout 31 }
