F5 LTM load balancing based on pool member CPU resources?
Hi all,
As titled, is that any ways to do so? is SNMP or irule can help on this?
We would like to load balance to busy page if the pool members are too busy.
Thanks a lot!
- Shiraz
Altostratus
Hello,
Yes, you can do this..
https://support.f5.com/csp/article/K9125
https://devcentral.f5.com/codeshare?sid=415
https://support.f5.com/csp/article/K14110
In one of the DevCentral solutions, (https://devcentral.f5.com/questions/monitor-pool-member-cpu-in-load-balancing-scheme) Denny suggested below which makes a lot of sense. :If you use something other than round robin for the default lb method, particularly Observed or Predictive, and an application health check that is better than just a ping or tcp port check, then most nodes won't get into this situation in the first place. The LTM will be able to respond dynamically to the load on the nodes as evidenced by their application response time, and you won't have to load agents on the nodes to poll CPU and such. Denny
Regards,
Mohammed
