Jaya_kumar_d_s_
Jul 04, 2016F5 Load balancer with Oracle Applications R12.2.5 is supported?
We are already using the F5 load balancer and we are planning to upgrade the oracle applications to latest R12.2.5? we want to know whether the F5 load balancer is supported.
- Tikka_Nagi_1315Historic F5 AccountWhat version of BIGIP software are you using? What modules are provisioned? Are you simply load balancing or also trying to secure the Oracle application using AFM/ASM?
- Chris_Grant
Employee
Based on our deployment guides, it doesn't look like it's officially supported yet:
https://f5.com/solutions/deployment-guides/oracle-application-server-10g-r2-big-ip-v11
This doesn't mean it won't work, but you may need to do some extra work or have a very good understanding of the underlying technology to get it to work right.
