Teerarat
May 09, 2014F5 Lacp doesn't up after on power f5 device
I have a question, I has f5 bigip 2200s and configuration LACP on port 1.1,1.2 It is work and then i shutdown f5 device after i boot f5 device,i seen status lacp is down what happen ?
- kunjan
What's the configuration on the switch to which it's connected? What's the port status on the switch? Any logs generated in the switch?
- Rory
Do the physical interfaces show as up?
Is your device in an Active, Standby or Offline state?
- Teerarat
I checked status physical interfaces is up bit status lacp is down, on the switch i configuration lacp mode active and f5 is passive
