jatin's avatar
jatin
Sep 16, 2019
F5 LAB LTM Fundanmentals IP address not saving
Hello All,
I am in the process of learning F5 and have installed the Partner_vLab_Package for the first time. However I have ran into a problem.
During my first setup, I can not configure the VMnet 1, 2 3 on VMWorkstation Pro as there is no option to enter the DHCP settings, I am using VMWorkstation Pro 15.
Once I boot the virtual machine in VM Workstation I am prompted to enter the network details, however when I run the software I am presented with a 127.x.x. address. Even though I execute the command "config" and my network settings is shown as 192.168.x.x, these parameters don't seem to be saving.
The instructions on the vlab are different to the workstation version as this is version 15, the instructions are for version 14. Then the LAMP server seems to be embedded into the package along with the VMWare software.
Would somebody be able to help with the networking side as the IP addresses don't seem to be saving when entered on the setup. I have attached two screen shots of the issue I am having
From jatin
