prashant_alhat_'s avatar
prashant_alhat_
Aug 28, 2017
F5 Interface
Hello Guys,
Can I make F5 interface Eg. 1.1, 1.2, 1.3 ... into Access port. ?
IF yes then How ? or F5 Interface By default in access port.
  • Hello Prashant,
    What do you mean with access port -
    L2 interface,
    or
    just interface, which can process traffic (enable),
    or
    something else?
    Regards,
    Preslav
  • Hi,
    When adding a VLAN to the interface select "untagged" from the drop down menu.
    Trunks that are “untagged” are dedicated to the single network segment of the VLAN of which they are a member.
    Hope this helps
