Introducing F5 Insight for ADSP
F5 Insight: Actionable intelligence to foster operational excellence
Introduction
F5 Insight for ADSP, a key component of the F5 Application Delivery and Security Platform (ADSP), helps teams monitor and secure apps that are spread across hybrid, multi-cloud and AI environments. In this article, I’ll highlight some of the key features and use cases addressed by F5 Insight.
Demo Videos
Demo Video: Introduction to F5 Insight for ADSP
Demo Video: F5 Insight - A Closer Look
What is F5 Insight for ADSP?
F5 Insight is a holistic solution that unifies every aspect of operating applications.  It provides end-to-end visibility and operational narratives.  It allows you to prioritize to-dos with health scores, anomaly detection, and report cards.  It delivers clarity and value faster with views built by F5 experts.  It provides expert guidance and optimization recommendations using natural language interactions.
F5 Insight is not intended to replace SIEM solutions like Splunk or Sentinel but serves a different, complementary purpose. It’s an open-source tool designed specifically for monitoring and analyzing metrics from your BIG-IP devices. By leveraging open-source telemetry tools, it collects and presents data in a central, easy-to-read dashboard. This eliminates the need to log into individual interfaces like the CLI or GUI to sift through logs and metrics, offering streamlined visibility into your BIG-IP estate for simplified monitoring and analysis.
Why is F5 Insight important?
Gain out-of-the-box actionable intelligence to optimize application delivery and security​​:
  • Get critical application and infrastructure performance data, operational analytics, security issues, and other telemetry in a unified tool.
  • Surface important KPIs and data points fast by querying data using natural language with model context protocol (MCP) support.
  • Optimize application delivery and security, as well as underlying resources, with built-in F5 expertise and guidance.
  • Share data with F5 and use F5 AI Data Fabric for application health scores, security grades, and automatic identification and categorization of apps by type and workload (In Limited Availability)
  • Speeds mean-time-to-innocence (MTTI) and mean-time-to-restore (MTTR) with actionable intelligence and proactive alerts.
  • Streamlines monitoring and analysis while being able to run on its own and integrate with your existing Grafana/VictoriaMetrics stacks.
  • Leverage data to make the business case and prove ROI for more resources, application migrations, or system refreshes.
How does F5 Insight work?
F5 Insight is deployed as a Virtual Machine.  This gives you full access and control of your F5 BIG-IP telemetry data.
The configuration is simple, log into the F5 Insight portal and add your BIG-IP devices.  There is no configuration needed on BIG-IP itself.
Ready to get started?  Log into the F5 Insight portal:
By default you will arrive at the Home screen.  From the navigation menu, under Manage, click BIG-IP Settings to add your BIG-IP devices.
Before we add the BIG-IP devices click the Data Centers tab and then Add Data Center.  This allows you to specify a location for the BIG-IP devices.
Give it a Name, San Jose, CA in this example.  Click Add Data Center.
Go back to the Devices tab and click Add Device.
Note that you can add a single device from here or add multiple devices using the Upload YAML Files (more on this later).  For now, let’s add a single device using the management address or Endpoint, Username and Password.
Scroll down and specify the Certificate Authority if using custom TLS certificates on BIG-IP devices.
Under Data Center select the Data Center created previously, San Jose, CA in this example.  Note: if you didn’t create a Data Center you can still do it now.
Under Modules select the BIG-IP Modules you are using.  In this example I selected Policy Firewall (or AFM).
Click Add Device.
The BIG-IP from San Jose has been added.
From the navigation menu select BIG-IP Device then Device Overview to see more details.
Note: you can select the specific Device you want to view.
Important details are shown on this screen.  Some items of interest are the BIG-IP version, system model or VM, Licenses and Enabled Modules.
The Home Screen displays System Report Cards and allows you to drill down into the individual widgets.  System Report Cards provide at-a-glance health indicators for four critical monitoring categories. Each card displays a status badge (Good, Warning, or Critical) based on deviation thresholds.
Note: you can filter the Home Screen to display a specific Data Center.
Adding Multiple BIG-IPs using YAML File Upload
For bulk onboarding or infrastructure-as-code workflows, import devices using YAML configuration. Using YAML streamlines bulk onboarding, ensures consistency, improves scalability, simplifies automation, and increases accuracy. It also ensures integration with IaC workflows and CI/CD pipelines—enabling reusable, version-controlled configurations.
From the BIG-IP Settings screen select Add Device.
Upload your Defaults and Receiver YAML files here or click Paste YAML to copy/paste them.
Note: YAML import also supports configuring F5 Insight features such as high availability, LLM Insights, AIDF, and data retention policies alongside device definitions.
Both BIG-IPs are now connected to F5 Insight
When you return to the BIG-IP Settings screen it should look like this:
A correctly configured ast-defaults.yaml file will look like the following.
Note: enter the username and password to log into your BIG-IPs
A correctly configured ast-receivers.yaml file will look like the following.
Note: enter a Device Name and Endpoint address.
Conclusion
F5 Insight for ADSP offers customizable visualizations and dashboards to help teams surface actionable metrics and KPIs tailored to your organization. It provides access to useful telemetry data for a deeper understanding of your environment, application behaviors, and complex BIG-IP deployments, all centralized in a single location.
  • Identification of root causes during outages/tickets.
  • Solves issues and struggles with Day 2 analysis of your BIG-IP Fleet and the applications therein.
  • Mitigates the problem of a lack of detailed visual information on your BIG-IP Fleet.
  • Set a foundation for the utilization of open-source tools and their benefits.
F5 Insight for ADSP BLOG
F5 Insight Documentation
F5 Insight Product Page
Published Mar 06, 2026
