phillbl_317539's avatar
phillbl_317539
Apr 14, 2017
f5 integration with NSX cross vcentre
hi,
we are looking at using nsx in a cross vcentre configuration with f5 load balancers. after doing a bit of reading i found the below in a f5 design guide:
NOTE: Cross-vCenter NSX functionality does not support load balancing service insertion
has anyone out there tried doing this or does this statement make the solution of cross vcentre and f5 just not possible? to me this would mean that if we use f5 then cross vcentre will not be possible.
we are using physical appliances. thanks
