ashish_solanki's avatar
3 years ago
F5 Health Monitor
Hi All,
I had created a pool with a node which is working on multiple ports mentioned below:
1055-1056/tcp,
2080/tcp,
2325/tcp,
19980/tcp,
27000-27016/tcp,
27500/tcp,
31010/tcp
when I add health monitor tcp to pool getting below error:
The monitor /Common/tcp has a wildcard destination service and cannot be associated with a node that has a zero service.
Need help to resolve this as I want to add tcp health moitor to pool however as of now I had added gateway_icmp.
  • Hi ashish_solanki,
    You can create a custom tcp monitor and set the "Alias Service Port". If you want to monitor multiple ports, you must create multiple monitors and add them to the pool.
