Sriram_Kannan_3's avatar
Sriram_Kannan_3
Jan 09, 2018
f5 health monitor - Decimal receive string
I need help with expression to listen to value 10.5.0.2006 in receive string for http/https monitor I couldn't make the monitor working to specifically look for the above decimal value
  • Hello, Try using the following string , and let me know if it works
    10\.5\.0\.2006
    • kolom's avatar
      kolom
      Thanks Blakely for you comment , mine would match other strings as well , so it was not the correct one to use.
    10\.5\.0\.2006
    • kolom_265617's avatar
      kolom_265617
