Abed_AL-R_26070's avatar
Abed_AL-R_26070
Aug 02, 2017
F5 failover traffic
Hi
We have F5 machine connected to one backbone switch. We're going to configure another backbone switch in case the first one went down. How can we configure in the F5 two interfaces in case the first one went down the other one will start forwarding the traffic ?
    • Abed_AL-R's avatar
      Abed_AL-R
      Thank you, But I got lost in that document :) There is too much information for my little question Any specific direction and direct to the point ? Thanks
    • eben_259100's avatar
      eben_259100
      what kind of core switch is it? have you worked with Virtual Port Channel on a nexus switch?
      Abed_AL-R
    • eben's avatar
      eben
  • Connect both F5 to upstream switches and then you need to connect two F5's together( don't use the system failover port). I would suggest use two failover cables to connect F5 together and make it a port channel trunk.
    Hope this helps.
    Thanks, Pankaj
  • Hi all,
    I have the same problems with Juniper SW. Do you have any guides to config LACP on Juniper? ON F5 i had config mode Active, Long (Timeout) and Auto (Link Selection Policy) but i didn't work.
    Thanks All!
