supportrsd_1762
Nov 14, 2014f5 edge client two factor authentication
Hello I have built a flow that checks if the client type is a edge client and then prompts for a radius auth. As of now there is a web prompt with the radius authentication. Is there any way to insted show the user a some other kind of prompt to type in the password, the coolest would be that the password prompt is in the edge client.
- kunjan
I think currently need a web prompt to collect the credentials. Are you using 2FA? For mobile, need to switch to weblogon mode for 2FA.
- supportrsd_1762
Thank you
