Nathaneil_Balag's avatar
Nathaneil_Balag
Nov 19, 2015
F5 DOS problem.
Hi guys,
Just want to ask why F5 mitigate and log DDOS attack even if I dont have any DOS and Log profile on my Virtual Servers.
Thank you.
Regards
  • Here is a good SOL that covers DDOS and the BIG-IP, SYN floods are just one type of DDOS attack the BIG-IP can help mitigate. [https://support.f5.com/kb/en-us/solutions/public/14000/800/sol14813.html](SOL14813: Detecting and mitigating DoS/DDoS attacks (11.4.x - 12.x))
    If you have one of the bigger appliances, like the the 5000 series, they come with hardware syn cookie protection. You can enable syn-cookie-status on a per virtual server basis, disabled by default, but enabled by default with some profiles like TCP & FastL4 for "hardware" syn flood protection. Also enabled on Self-IPs. It's worth noting you need auto last hop enabled for hardware syn cookie protection to work.
    From tmsh:
    root@(BIG-IP-VE-1)(cfg-sync Standalone)(ModuleNotLicensed:Active)(/Common)(tmos) list ltm virtual test_443 syn-cookie-status
    ltm virtual test_443 { syn-cookie-status not-activated }
    You can also look in /var/log/ltm for syn cookie threshold messages. Take your time and read the article, there is a lot of good "starting" information in it. Out of the box f5s BIG-IP has an arsenal of DDOS protection, it doesn't stop at SYN floods. Here is a quick list from the SOL of DDOS attacks and how big-ip mitigates them:
    Attack------- Mitigation
    SYN flood -- SYN cookie protection
    ICMP flood -- Maximum reject rate
    Peer-to-peer --The BIG-IP system is a port-deny device, and prevents many common exploits by not passing the attack through to the server.
    IP fragmentation -- The BIG-IP system drops IP fragments that fail to meet a certain threshold, unless the fragment is the last in a communication.
    Slowloris -- iRules can filter out well-known attacks.
    UDP flood -- UDP idle session timeout
    Ping of death -- The BIG-IP system is hardened to resist this attack. If the attack is against a virtual server with the Any IP feature enabled, then these packets are sent on to the server.
    Land --The BIG-IP system is hardened to resist this attack, and does not send this type of packet to the server.
    Teardrop -- The BIG-IP system correctly checks frame alignment and discards improperly aligned fragments to process these attacks.
    Data attack -- The BIG-IP system is a port-deny device, and prevents many common exploits by not passing the attack through to the server.
    Nuke --The BIG-IP system denies ports unless they are specifically enabled.
    Sub 7 -- The BIG-IP system denies high ports unless they are specifically enabled.
  • Hi everyone,
    Thank you for all your suggestion. I am still testing it on my VM LAB.
    Regards
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      if you feel one of the answers was good please flag it as an answer to your question.
