Basem_Zaben_139's avatar
Basem_Zaben_139
10 years ago
f5 Captcha engine
Is it possible to utilize F5 captcha engine to be used from our website? if yes, how?
  • Is it possible to utilize F5 captcha engine to be used from our website?
    you are taking about captcha in dos profile, aren't you?
    i understand it will be used when criteria is met. even you can set it very low, it won't be triggered on the first request.
    • Hussein_Ghazy_3's avatar
      Hussein_Ghazy_3
      Yes you can use it and it is under the DoS Profile, under the ASM, create a new DoS Profile enable Application Security, Choose the captcha features and assign the DoS profile under the VS Security Tab.
      Hussein_Ghazy_3
