F5 Big IP Web GUI not picking up changes
Hello,
Thank you for your time. I have a problem with one of our f5's. The other day i wanted to change the root and admin passwords. I can change them in the web GUI just fine and click update.
The problem is, the F5 is not picking up on the change.
Today i had another problem when our whole VPN died. I noticed it was using LDAP creds which expired. So i changed the password for LDAP but also, it did not pick up the change. The new entry is still in the WebGUI but its just not picking it up.
I can create pools, health checks, all that just fine. (even a new LDAP check i made works)
But its not picking up Admin/root password changes or changing the VPN LDAP user/pass. I click update, does not give any error.. Just ignores the change.
version is BIG-IP 11.6.0 Build 6.0.442 Hotfix HF6 Any ideas?
Thank you in advance!
- Salim_83682Historic F5 Account
Anything (errors) in the logs when you try to update the configuration ?
I'd suggest opening up a case with F5 Support to investigate further. Configurations changes via the GUI should be effective right away and saved to disk as well.
Salim
- zpavlovic_28213
Nothing specific in logs :(
Thank you for your time! Ill try with f5 support
- zpavlovic_28213
Nothing specific in logs unfortunately
have you tried to log out and log in again to see if changes applied like this?
- HussainT_289006
Hi zpavlovic,
Either change it as admin in the GUI via System/Platform or login via SSH and enter
. Specify the new password and you should be all good. If you are running a redundant pair, you'll want to perform a config sync to mirror the change to the other unit.passwd root- zpavlovic_28213
thnx, ill try that.
WIll update
- zpavlovic_28213
Hello.
I tryed to login as admin and then go to system platform and change the admin pass. When i change it, it logs me out as expected but when i try to login back into it, it does not recognise the new password so i have to login with the old one
