peter_113959's avatar
peter_113959
Sep 13, 2009
F5 big IP LTM failed over /load balance
hi all , how to setup a pool that running on 2 F5 , running like a cluster so if one of the F5 failed , there will be another on.
your advice is highly appreciated.
thanks.
  • hoolio's avatar
    hoolio
    If you configure the two LTM's in active/standby mode and sync the configuration to the peer unit, the peer will have the same load balancing configuration. You can then configure which types of failures will trigger a failover from the currently active unit to the peer.
    All of this is described quite comprehensively in the manuals on AskF5.com. If you have a more specific scenario, can you provide details on it so we can provide more specific suggestions?
    Thanks,
    Aaron
  • thanks mate, i check on the manual first,before i decide how to do with it. will come back here in a day time
