Rysheen_312712
Mar 06, 2017F5 Authentication with web application using CAC
Currently using F5 Authentication via CAC with a web application. Our Web applications authentication is via EDIPI number so we have to create account within the application based on that. What can we do to change from EDIPI to include email address.
We use a similar method, in the string to query you should have something like following:
an EXTRACTEDIPI iRULE
an Access Policy to call the event
and within the access policy a custom search string .. (orclsecondaryuid=%{session.custom.edipi})
The iRULE will looking something like this ..
set EDIPI [string range [findstr [ACCESS::session data get session.ssl.cert.subject] "CN=" 3 ","] [expr [string last "." [findstr [ACCESS::session data get session.ssl.cert.subject] "CN=" 3 ","]] + 1] end] if { [string tolower $EDIPI] equals "blahblah" } { set EDIPI [findstr [ACCESS::session data get session.ssl.cert.subject] "CN=" 3 "."] The CN = 3 is the important part, this is how many spaces from the period "." it will search for the requested information. You would set this to the email portion
