F5 ASM : View System Variable from CLI
Hello,
For a subject of compliance, I need to know the values of the variable systems. Example : guaranteed_remote_logging ; total_xml_request.
Since the GUI, it's easy enough. But I would like to run a "tmsh" command that lists the asm variables and their value.
There is the command: "tmsh list sys db" but this one is used for the hardware.
Thanks.
- suttonsc
Employee
The settings for ASM Advanced Settings are not accessible from tmsh. You will need to use REST or the UI.
Example:
curl -sku admin:admin https://${bigip_mgmt}/mgmt/tm/asm/advanced-settings?\$filter=name%20eq%20"total_xml_memory" | jq . { "kind": "tm:asm:advanced-settings:advanced-settingcollectionstate", "selfLink": "https://localhost/mgmt/tm/asm/advanced-settings?ver=13.1.0&$filter=name%20eq%20total_xml_memory", "totalItems": 1, "items": [ { "value": 0, "isUserDefined": false, "maxValue": 1073741824, "name": "total_xml_memory", "lastUpdateMicros": 1528371962000000, "kind": "tm:asm:advanced-settings:advanced-settingstate", "selfLink": "https://localhost/mgmt/tm/asm/advanced-settings/O6z_jDkjBalpmAiwURU9HQ?ver=13.1.0", "minValue": 0, "format": "integer", "id": "O6z_jDkjBalpmAiwURU9HQ", "defaultValue": 0, "units": "Bytes" } ] }The logging is different and can be accessed via the specific profile or all profiles.
tmsh list security log profile Guarantee_Log_Profile application { /Common/Guarantee_Log_Profile { guarantee-logging } } security log profile Guarantee_Log_Profile { application { Guarantee_Log_Profile { guarantee-logging enabled } } }Does this cover what you are looking for?
- suttonsc
Employee
Adding reply to the answers section.
Example:
curl -sku admin:admin https://${bigip_mgmt}/mgmt/tm/asm/advanced-settings?\$filter=name%20eq%20"total_xml_memory" | jq . { "kind": "tm:asm:advanced-settings:advanced-settingcollectionstate", "selfLink": "https://localhost/mgmt/tm/asm/advanced-settings?ver=13.1.0&$filter=name%20eq%20total_xml_memory", "totalItems": 1, "items": [ { "value": 0, "isUserDefined": false, "maxValue": 1073741824, "name": "total_xml_memory", "lastUpdateMicros": 1528371962000000, "kind": "tm:asm:advanced-settings:advanced-settingstate", "selfLink": "https://localhost/mgmt/tm/asm/advanced-settings/O6z_jDkjBalpmAiwURU9HQ?ver=13.1.0", "minValue": 0, "format": "integer", "id": "O6z_jDkjBalpmAiwURU9HQ", "defaultValue": 0, "units": "Bytes" } ] } `The logging is different and can be accessed via the specific profile or all profiles.` tmsh list security log profile Guarantee_Log_Profile application { /Common/Guarantee_Log_Profile { guarantee-logging } } security log profile Guarantee_Log_Profile { application { Guarantee_Log_Profile { guarantee-logging enabled } } }
