Mayur_Jadhav's avatar
Jan 01, 2020
F5 APM Edge client not reverting window machine proxy settings to defalut/back to original
Hi All,
Facing issue with Proxy setting on client machine. I have followed below artical,
https://support.f5.com/csp/article/K15004730
As per artical ,When you configure BIG-IP APM network access to use a proxy PAC file and the client device has local proxy settings configured, BIG-IP Edge Client modifies the system proxy configuration to ensure that VPN tunnel traffic uses the proxy configuration in the network access configuration on the BIG-IP APM system, while other traffic uses the local proxy configuration. To accomplish this, BIG-IP Edge Client merges users’ local proxy settings with the remote proxy settings on the BIG-IP APM system.
The same is happening, The proxy setting are merged in new PAC file and stored at http://127.0.0.1:xxxx but after disconnecting VPN. The proxy settings are not reverting back to Original.
Thats why users are not able to access due to wrong proxy settings.
Can anyone know if this is a known issue or bug?
Thanks,
Mayur
