F5 APM BIGIP Edge Client and DuoSecurity
Hi
I configured F5 APM SSL VPN using DuoSecurity as this link https://www.duosecurity.com/docs/f5bigip I could use Web access but could not use BIGIP Edge client access.
I though that may be the Edge client could not run the script
In the “Customization” tab of that Access Policy, select customization type of “general UI” and click “Find Customization”. Open the Advanced Customization Editor. Navigate through the Access Profiles tree to the Common folder beneath your Access Policy. Click on the footer.inc item and then insert the following JS snippet at the end of the Advanced Customization Editor Footer text input box and click Save:
Is there any solution?
Phong
- Phong_Tang_7213
Altostratus
The script is:
script src="https://api-XXXXXXXX.duosecurity.com/frame/hosted/Duo-F5-BIG-IP-v1.js">
Phong
- Jason_Keating
Altostratus
What version of Big-IP are you using, they only support up to 11.4 currently. I have been talking to them about further support because as you guessed, the script fails on 11.5.1 HF7.
Apparently something is coming in the next week or two.
- Phong_Tang_7213
Altostratus
I used 11.5.1 HF3. It worked
- Jason_Keating_4
- Phong_Tang_7213
Altostratus
