Ichnafi
7 years agoF5 Analytics 3.7.x - Questions and Problems
Hello Community,
I stumbeld upon the F5 Analytics iApp and so I wanted to give it a try.
My environmental requirement:- Splunk Version 6.5
- Communication from BigIP to Splunk HTTP Event Collector is working (telnet to Splunk port 8088)
- Syslog/Analytics data MUST use Management interface of BigIP
- no HSL
- iApp Version 3.7.1 (and also 3.7.2rc4)* BIG-IP v12.1.2 (Build 2.0.276) and BIG-IP v13.1.1.2 (Build 0.0.4)
Result: failed* Error in /var/log/ltm:
Script (/Common/F5-Analytics-send_stats) generated this Tcl error: (script did not successfully complete: (01020036:3: The requested RADIUS Server (/Common/F5-Analytics.app) was not found. while executing "tmsh::get_config auth radius-server /Common/$appname.app/$radius_ihealth" invoked from within "lindex [tmsh::get_config auth radius-server /Common/$appname.app/$radius_ihealth] 0" invoked from within "set obj [lindex [tmsh::get_config auth radius-server /Common/$appname.app/$radius_ihealth] 0]" line:41))
- iApp Version 3.7.0
- BIG-IP v12.1.2 (Build 2.0.276)
- Result: not quite sure
Some Error in /var/log/ltm:
Stats Response for F5-Analytics 1542956978 0 failData publisher not found or not implemented when processing request (unknown request), tag (2901).
Thus I seem to get Data but I don't know if this is correct.
- Health values on "Start" Dashboard are always 0
- Device Health 0 as well, or even NaN,
- Most field just have no data
- SSL Dashboard: no data
- Do I have to configure Analytic Profiles on the BigIP itself to get more data?
- when you can use only the Mgmt-Port, what are the best settings in the iApp?
- Can i user "Module High Speed Logging Streams -> yes" when I can only use the Mgmt-Port?
- Is there a guide, that shows how to setup the BigIP itself (i.e. analytic profiles on VS) to get the most out of the app? I followed the "Deploying the F5 Analytics iApp Template" but the result is not overwhelming
- Is there an explanation for the meaning of all the diagramms and stuff you get? Example: What does "Server Latency Health 100,0%" mean?
I'm grateful for any hint, tip, advice from you guys.
Cheers Ichnafi
- UniFirst1_22521
Did you ever get answers to these questions? I am implementing now and have many of the same questions.
- Ichnafi
Nope. I gave up on that stuff. But if you get it to work properly, a in depth guide would be very much appreciated :) .
