satish_txt_2254's avatar
May 15, 2018
F5 10200v L7 concurrent connection limit
I was reading datasheet and found following numbers
L7 requests per second: 4M
L4 connections per second: 1.5M
L4 HTTP requests per second: 14M
Maximum L4 concurrent connections: 80M
Throughput: 84 Gbps/40 Gbps L4/L7
But i want to know what would be concurrent L7 TCP connection limit on these hardware? In short we want to run XMPP application (with SSL) with persistent connection so trying to find max concurrent client can talk to F5.
