F5 / SCOM Discovery Issues
Morning all,
I wonder if you can shed any light on an issue I am having trying to get the F5 devices setup with in the Microsoft SCOM console.
I have installed the MP with little fuss onto the RMS Server in my environment.
The discovery wizard can see the F5 device when given the IP address and the user credentials asked for.
The status of the discovery states: an attempt to connect to the iControl blah blah was a success
And then everything just stops,
The discovery process doesn’t go any further than this (even when left for 48 hours)
The trace.log file states the following
Global Critical: 0 : [2/25/2013 9:43:37 AM]The service F5MonitoringService is starting
Configuration Warning: 0 : [2/25/2013 9:44:07 AM]Microsoft Operations Manager Data Warehouse access has been disabled due to missing host name or database name.
Global Warning: 0 : [2/25/2013 10:46:42 AM]Ignored discovery request for device since a pending request already exists
Storage Warning: 62676156 : [2/25/2013 10:54:49 AM][OperationTracker] Ignoring thread 16 request to cancel operation. There is no active operation on thread [14]:Discovery [F5 Device [];Type=Default, UpdateBig3D]
Storage Warning: 12611187 : [2/25/2013 10:54:49 AM][OperationTracker] Ignoring thread 16 request to cancel operation. There is no active operation on thread [14]:Discovery [F5 Device [];Type=Default, UpdateBig3D]
Storage Warning: 9482527 : [2/25/2013 10:54:49 AM][OperationTracker] Ignoring thread 16 request to cancel operation. There is no active operation on thread [14]:Discovery [F5 Device [];Type=Default, UpdateBig3D]
Global Warning: 15510466 : [2/25/2013 10:54:49 AM][AsyncNotification] DiscoveryManager Progress notification was shutdown; discarding: Source=F5 Device [] Progress=action=Execute device discovery, duration=4192.3sec, state=Failure [The iControl network call to device was aborted ]
Global Error: 0 : [2/25/2013 10:54:49 AM]Failed to discover device at address: Network-related failure has occurred: The iControl network call to device was aborted F5Networks.Protocols.iControl.iControlException: The iControl network call to device was aborted at F5Networks.ManagementPack.Discovery.Networking.iControlDiscovery._MakeSoapCall[ReturnType](GenericVoidHandler`1 soapAsyncBegin, GenericTypeHandler`2 soapAsyncComplete) at F5Networks.ManagementPack.Discovery.Networking.iControlDiscovery.CoreGetSystemLocalTime() at F5Networks.ManagementPack.Discovery.Networking.iControlDiscoveryBase.<>c__DisplayClass1.b__0() at F5Networks.ProgressTracking.Tracer.<>c__DisplayClass1.b__0() at F5Networks.ProgressTracking.Tracer.DoActionWithTryFinally[TReturnResult](GenericVoidHandler`1 activeCode, VoidVoidDelegate preCode, VoidGenericHandler`1 postCode, VoidVoidDelegate postCodeSuccess, VoidGenericHandler`1 postCodeFailure) at F5Networks.ProgressTracking.Tracer.DoActionWithTryFinally(VoidVoidDelegate activeCode, VoidVoidDelegate preCode, VoidGenericHandler`1 postCode, VoidVoidDelegate postCodeSuccess, VoidGenericHandler`1 postCodeFailure) at F5Networks.ProgressTracking.Tracer.DoActionWithTryFinally(VoidVoidDelegate activeCode, VoidVoidDelegate preCode, VoidVoidDelegate postCodeSuccess, VoidGenericHandler`1 postCodeFailure) at F5Networks.ProgressTracking.Tracer.TraceCall(VoidVoidDelegate activeCode, String action, String area, String category, Int32 id) at F5Networks.ManagementPack.Discovery.Networking.iControlDiscoveryBase.get_SystemLocalTime() at F5Networks.ManagementPack.Discovery.DiscoveryManager.DiscoverDevice._ConnectToDeviceAndPushCertificate(Credentials deviceCredentials, ManagementPackIQueryConnection deviceConnection, Boolean refreshAllDeviceInfo) at F5Networks.ManagementPack.Discovery.DiscoveryManager.DiscoverDevice._ConnectToDevice(Credentials deviceCredentials, Boolean refreshAllDeviceInfo) at F5Networks.ManagementPack.Discovery.DiscoveryManager.DiscoverDevice._Execute(DiscoveryInfo discoveryInfo) at F5Networks.ManagementPack.Discovery.DiscoveryManager.DiscoverDevice.<>c__DisplayClassc.b__a() at F5Networks.ProgressTracking.ProgressEventSourceBase`1.<>c__DisplayClass6.b__5() at F5Networks.ProgressTracking.ProgressEventSourceBase`1.<>c__DisplayClassb`1.b__8() at F5Networks.ProgressTracking.Tracer.DoActionWithTryFinally[TReturnResult](GenericVoidHandler`1 activeCode, VoidVoidDelegate preCode, VoidGenericHandler`1 postCode, VoidVoidDelegate postCodeSuccess, VoidGenericHandler`1 postCodeFailure) at F5Networks.ProgressTracking.Tracer.DoActionWithTryFinally[TReturnResult](GenericVoidHandler`1 activeCode, VoidVoidDelegate preCode, VoidGenericHandler`1 postCode) at F5Networks.ProgressTracking.ProgressEventSourceBase`1.DoActionWithProgressNotification[TReturnResult](GenericVoidHandler`1 activeCode, String action) at F5Networks.ProgressTracking.ProgressEventSourceBase`1.DoActionWithProgressNotification(VoidVoidDelegate activeCode, String action) at F5Networks.ManagementPack.Discovery.DiscoveryManager.DiscoverDevice.Execute(DiscoveryInfo discoveryInfo) at F5Networks.ManagementPack.Discovery.DiscoveryManager._SyncFinishDiscovery(DiscoverDeviceHandler discoveryHandler, DiscoveryInfo info) at F5Networks.ManagementPack.Discovery.DiscoveryManager._AsyncFinishDiscovery(AsyncDiscoveryInfo asyncInfo)
Global Critical: 0 : [2/25/2013 10:54:49 AM]The service F5MonitoringService has exited with exit code 0
Can anyone plkease shed any light on the above?
Cheers in advance
Ian
- Dimi_18916
G'day,
I had exactly the same problem. You need to manually upgrade the BIGIP agent on the F5 device to the latest version and this should fix your issue. These two links will help you on your way.
https://support.f5.com/kb/en-us/sol...11302.html
https://support.f5.com/kb/en-us/pro...ually.html
Cheers,
Dimi
