Flip's avatar
Flip
May 20, 2020
External Monitor + cURL + TFTP + Route Domains
I'm trying to do a external monitor to check if a tftp server is alive.
During the development of the external monitor in a LAB, without route domains all works fine.
After applying in production with route domains it no longer works as expected.
The basic of the external monitor is:
curl --globoff --silent --max-time 5 -o /dev/null tftp://[10.xx.xx.180]:69/probef5
After a packet capture we see it is the LTM reply with a ICMP Port Unreachable
Even using tftp command in bash, the firt time run as expected, second in a row, it fail with timeout
[adm@LTM:/S1-green-P::Active:Changes Pending] run # rdexec 14 tftp -v 10.xx.xx.180 -c get probef5
Connected to 10.xx.xx.180 (10.xx.xx.180), port 69
getting from 10.xx.xx.180:probef5 to probef5 [netascii]
Received 7 bytes in 0.0 seconds [1640 bit/s]
Transfer timed out.
Any help would be appreciated.
