F5user13_114603
Cirrus
Mar 26, 2017Event logging for LTM module
Is there an option similar to Event logs of the ASM in the GUI or CLI where real times logs can be viewed for LTM traffic.
This will help troubleshooting connection issues between client and F5 or F5 and back end server.
Not out of the box. You could increase the logging level on IP, construct an iRule that will send relevant data to /var/log/ltm (log local0.) and tail the ltm log on the cli (tail -f /var/log/ltm) and/or perform a tcpdump on the traffic between client and BIG-IP and on the traffic between BIG-IP and server.
Cheers,
Kees
