jj24_43946's avatar
jj24_43946
Apr 02, 2012
evaluate IP::remote_addr as string
Hello and thanks in advance for your expertise:
My problem is that I want to be able to assign traffic to different pools based on the end digit of an IP address. For example, if it's from 0-4 go to POOL A, and if from 5-9 go POOL B.
What is the most efficient, resource-wise, method to achieve this? Below is what I'm doing right now.
when CLIENT_ACCEPTED {
set client_ip [IP::remote_addr]
if { [ $client_ip ends with "5" ] } {
pool poolB
return
Again, thanks for any assistance anyone can provide.
  • when CLIENT_ACCEPTED {
    set client_ip [getfield [IP::remote_addr] . 4]
    if { $client_ip < 5 } {
    pool POOLA
    else {
    pool POOLB
