Etherchannel with Nexus vpc, suggestions ?
Looking for best practices for configuring etherchannel/portchannle on a pair of 3900 (10.2, to be upgraded to 11.3 afterwards), these will connect to a Nexus 2248 (N5K core) vpc.
Suggestions please.
Also I would appreciate if someone can put their lab/configuration snippet so I can pick the usable ones (I don't have GUI access to the boxes only console)
- Hamish
Cirrocumulus
Works fine. The only diff between a normal channel and vpc (If we ignore the base vpc cnfig, peer links etc of the nexus) is the extra vlc vpcnum statement in the port-channel itself. I have 20Gbps (2x 10Gbps) vpc's to my viprions (n7010 cores). I do have a couple of 1600's on a VPC to 2248's with 7010 core as well though.
H - Hamish
Cirrocumulus
Oh... You can't do routing protocols over vPC's... It's not supported (And worst case can have nasty effects like crashing your nexus).
H - Ajmal_2608
Thanks Hamish
At this point we are not going to run any routing protocols, so I thing we should be good.
Could you please suggest any configuration guideline for this ?
- Hamish
Cirrocumulus
Just configure like any other port-channel. - Ajmal_2608
This worked for me
trunk PO1 {
interfaces 1.1
interfaces 1.2
vlan external {
tag 10
trunks PO1
