andyt_102255's avatar
andyt_102255
Sep 14, 2009
error while using Proxy Pass by kirk bauer
I am running Kirk's Proxy Pass on several pairs of f5's. It is working fine on two pairs without any issues. On the third pair it is getting the following error:
TCL error: Rule proxypass - Illegal argument. Illegal argument. Illegal argument. Illegal argument. Ille (line 77) invoked from within "HTTP::header values "Set-Cookie""
The data group list is the same for all three environments. The only thing I see that is different between the three environments is the release of the LTM. I am running BIG-IP 9.1.2 Build 40.2 on the pair that it does not work. I am running
BIG-IP 9.4.6 Build 401.0 Final and BIG-IP 9.3.1 Build 37.1 on the versions that it works. Has anyone run into this issue before? Thanks for any input.
  • hoolio's avatar
    hoolio
    The option for HTTP::header values was added in 9.4.0. So you could remove the s from values to use the proxypass iRule in versions prior to 9.4.0. The downside is that the iRule won't be able to parse multiple instances of the same header name.
    Aaron
