Error while installing UCS
Hi All,
i am getting following errors when installing back up UCS on fips licensed box :
key_import_file: error 7 - error:0D094068:asn1 encoding routines:d2i_ASN1_SET:bad tag
Seems to be issue with importing key .... Please if someone can let me know what to do next to resolve the errors .
- if you got support contact TAC.
- StephanManthey
Nacreous
Hi SynACk,
involving support as recommended by boneyard is first choice. As a workaround I would recommend the step by step approach if this needs to fix asap.a) license the new unit:
get_dossier -b base-registration-key (get new license from license.f5.com) cat > /config/bigip.license (Paste new license; finish paste with ) reloadlicb) merge extracted basic configuration data from /config/bigip_base.conf without floating self IPs!:
cat > /var/tmp/base_config (paste relevant data from base config file; finish paste with ) tmsh load sys config merge file /var/tmp/base_config tmsh save sys configc) put new unit in forced offline mode:
tmsh run sys failover offlined) rebuild the device certificate, device trust and the device cluster, run config sync
e) release new device from offline mode:
tmsh run sys failover onlineThanks, Stephan
