  • Alexander_Kova1's avatar
    Alexander_Kova1
    Historic F5 Account
    You can obtain the FirePass Client Setup package containing the API DLL and all other client-side components from your FirePass controller.
    1. Using an Admin login, log in to the Firepass Admin Console.
    2. Navigate to the Device Management : Client Downloads : Windows (x86) : Download screen and select “FirePass Client COM API”, “Network Access” and “Application Tunnels” than press button.
    3. Select “Download” tab and click on “Download customized package link” to save installation package.
    4. Install downloaded package on you PC.
  • Do you mean , having F5 networks vpn client installed and the firepass client sdk "FPSDK" on my pc is not enough ?
