neeeewbie's avatar
Nov 05, 2019
Error occur after installed 10.0.1 build 354.0 on bigip-6900
Hi guys !!!
I have some problem
The device can't read boot disk after installed 10.0.1 build 354.0 OS on 6900
I was exchanged disk1,2 location but that is not work ...
I was selected other boot location when the device booting but that was not work
and displayed "Error 21 : selected disk does not exist"
I also did EUD Test but everything is passed
I can't find SOL documents relate to this situation
Plz let me know if you experienced this situation or have you documents !
thank you !!!
  • Why haven't you upgrade your BigIP yet... are you really stuck with 10.x versions ?
    This could possibly with a hardware issue. Go for an RMA.
    • neeeewbie's avatar
      neeeewbie
      Icon for MVP rankMVP
      Thank you. However, this equipment has already expired EoL and EoS.
      In my opinion, I didn't choose the 6900 device when I made my booting USB. Is this a problem?
      • jaikumar_f5's avatar
        jaikumar_f5
        Icon for Noctilucent rankNoctilucent
        I dont think thats really important, sometimes there are platforms which dont get listed too.
        BTW where you able to fix this.
