ERR_CONNECTION_REFUSED <local host>refused to connect.</local>
We Have a pair of LTM devices active one is working fine and other one i'm not able login via GUI it getting an a connection refused error I can able to login via CLI and also
I tried cmd: bigstart restart httpd is says below error
Stopping httpd: [FAILED] Starting httpd: httpd: Syntax error on line 149 of /etc/httpd/conf/httpd.conf: Cannot load /etc/httpd/modules/mod_f5_auth_cookie.so into server: /etc/httpd/modules/mod_f5_auth_cookie.so: undefined
please let me know what needs to done to fix this issue
- Ilian_Ivanov
- Jad_Tabbara__J1
Check the status of following :
bigstart status httpd tomcat syslog-ngIf they are all running, you can try to restart the following :
bigstart restart httpd tomcatIf it did not resolve the issue, you are good to restart the standby unit to force the reload of all services.
Let us know
Regards
