Equal Sign in Proxypass Regular Expression Replacement String
Recognizing that I may be misusing the proxypass irule, assuming I want to replace a string matched by a regular expression with another string that contains an equal sign, how would I protect the equal sign from being the terminator for the replacement string? I've tried other delimiters, TCL backslash and bracket protection and HTML %3D, to no avail. E.g.,
/ := =^(.*?)/$=${1}/foo.jsp?var1{=}value1&var2{=}value2&=
Where "{=}" should be replaced with a literal equal sign.
Thanks.
- larry_p_134874
If anyone ends up reading this, I solved this (sort of) by replacing the hard-coded ‘=’ in the proxypass irule with another delimiter (a comma worked in my case).
