Enterprise Vault with Exchange 2007 LTM+APM
We are currently implementing Exchange 2007 with Symantec Enterprise Vault. I've managed to get everything working except.
Enterprise Vault Via Outlook Plugin without having to re-enter the username and password again on the OWA page which is displayed inside the plugin.
Just to elaborate on the irules.
To redirect the traffic to the enterprise vault we have added this in the irule
"/enterprisevault*" { pool /Common/EV_POOL return COMPRESS::disable CACHE::disable }
To disable the APM session under evaluation (MRHsession). We use the below iRule.
when HTTP_REQUEST { if { ( [HTTP::cookie exists MRHSession] ) and not ( [ACCESS::session exists -state_allow [HTTP::cookie value MRHSession]] ) } { if { ( [HTTP::uri] ne [ACCESS::session data get session.server.landinguri] ) and not ( [ACCESS::session data get session.server.landinguri] eq "" ) } { HTTP::redirect [ACCESS::session data get session.server.landinguri] }
When a user is within an OWA session in a web browser does change the URI to /enterprisevault there are no problems.The user gets redirected the EV_Pool and Enterprise vault also works well with the web browser.
With the outlook client. When a user types in his username and password for outlook anywhere everything works. Only when the user clicks on the Enterprise Vault Plugin. The user used to get an error message " APM Session Currently under Evaluation" To get rid of this error we used the MRH irule. However now there is a OWA page displayed within the plugin where the user has to re-enter the username and password to access Enterprise Vault.
This is a TMG replacement project. It works without reauthentication on TMG. Can we get this working without having to re-authenticate?
P.S: OWA page is customized on APM
Has anyone got the Enterprise Vault working via APM all devcentral articles are with LTM
- mikeshimkus_111Historic F5 Account
Hi Mark, to disable APM you'd want to use ACCESS::disable in your iRule. However, it sounds like you want to use SSO for requests from Outlook to Enterprise Vault instead, correct? That would avoid poking a hole in your APM deployment.
You may be able to get away with simply invoking the forms SSO for those requests. For example, try modifying the "_select_sso" iRule to include that URI. It's possible you may need to adjust the forms SSO object a bit as well to make this work (I've no way to test it here):
when ACCESS_ACL_ALLOWED { set req_uri [string tolower [HTTP::uri]] if { $req_uri contains "/owa/auth" || $req_uri contains "/enterprisevault" } { WEBSSO::select [set foo /Common/exchange.app/exch_form_basedv2_sso] } unset req_uri } - Mark_II
Hi Mikes,
After adding this to the SSO iRule. We keep getting this NTLM Popups and every email under archive we click we get the NTLM Popup.
Below is a sample screenshot.
All iRules Assigned
1) MS_Exchange_2007_owa_redirect_irule7
when HTTP_REQUEST { if { ([HTTP::uri] == "/") } { HTTP::redirect https://[HTTP::host]/owa/ } }
- MS_Exchange_2007_login_timeout
when RULE_INIT { set static::cookie_sessionid [format "sessionid=null; path=/; Expires=Thurs, 01-Jan-1970 00:00:00 GMT;"] set static::cookie_cadata [format "cadata=null; path=/; Expires=Thurs, 01-Jan-1970 00:00:00 GMT;"] }
when ACCESS_SESSION_STARTED { if { [string tolower [HTTP::uri]] contains "ua=0" } { ACCESS::session remove } }
when ACCESS_ACL_ALLOWED { set apm_mrhsession [HTTP::cookie value "MRHSession"] if { [table lookup $apm_mrhsession] == "EXCHANGE_LOGOUT" } { ACCESS::session remove table delete $apm_mrhsession } }
when HTTP_REQUEST { set isset 0 if {[string tolower [HTTP::uri]] starts_with "/owa" } { if {[string tolower [HTTP::uri]] contains "logoff" } { ACCESS::session remove HTTP::respond 302 Location "https://[HTTP::host]/vdesk/hangup.php3" "Set-Cookie" $static::cookie_sessionid "Set-Cookie" $static::cookie_cadata } else { if { [string tolower [HTTP::uri]] contains "ua=0" } { set mrhsession [HTTP::cookie value "MRHSession"] set isset 1 } } } } when HTTP_RESPONSE { if { $isset == 1 } { if { $mrhsession != "" && [HTTP::status] == 440 } { table set $apm_mrhsession "EXCHANGE_LOGOUT" return } } }
3) MS_Exchange_2007_apm_combined_pool_irule7 when ACCESS_ACL_ALLOWED { set sessionid [ACCESS::session data get "session.user.sessionid"] switch -glob -- [string tolower [HTTP::path]] { "/microsoft-server-activesync" { pool /Common/MS_Exchange_2007.app/MS_Exchange_2007_as_pool7 persist uie $sessionid 7200 COMPRESS::disable CACHE::disable return } "/owa" {
pool /Common/MS_Exchange_2007.app/MS_Exchange_2007_owa_pool7 persist uie $sessionid 7200 return } "/ews*" { pool /Common/MS_Exchange_2007.app/MS_Exchange_2007_oa_pool7 persist uie $sessionid 7200 COMPRESS::disable CACHE::disable return } "/ecp*" { pool /Common/MS_Exchange_2007.app/MS_Exchange_2007_owa_pool7 persist uie $sessionid 7200 return } "/oab*" { pool /Common/MS_Exchange_2007.app/MS_Exchange_2007_oa_pool7 persist none return } "/rpc/rpcproxy.dll*" { pool /Common/MS_Exchange_2007.app/MS_Exchange_2007_oa_pool7 COMPRESS::disable CACHE::disable persist uie $sessionid 7200 return } "/autodiscover*" { pool /Common/MS_Exchange_2007.app/MS_Exchange_2007_ad_pool7 persist none return } "/enterprisevault*" { pool /Common/EV_POOL return COMPRESS::disable CACHE::disable } default { This final section takes all traffic that has not otherwise been accounted for and sends it to the pool for Outlook Web App pool /Common/MS_Exchange_2007.app/MS_Exchange_2007_owa_pool7 persist uie $sessionid 7200 } }} when HTTP_RESPONSE { if { [string tolower [HTTP::header values "WWW-Authenticate"]] contains "negotiate"} { ONECONNECT::reuse disable ONECONNECT::detach disable NTLM::disable } if {[HTTP::header exists "Transfer-Encoding"]} { HTTP::payload rechunk } }
- MS_Exchange_2007_select_sso_irule7
when ACCESS_ACL_ALLOWED { set req_uri [string tolower [HTTP::uri]] if { $req_uri contains "/owa/auth" } { WEBSSO::select [set foo /Common/MS_Exchange_2007.app/exch_form_basedv2_sso] } unset req_uri }
5: MRHSession when HTTP_REQUEST { if { ( [HTTP::cookie exists MRHSession] ) and not ( [ACCESS::session exists -state_allow [HTTP::cookie value MRHSession]] ) } { if { ( [HTTP::uri] ne [ACCESS::session data get session.server.landinguri] ) and not ( [ACCESS::session data get session.server.landinguri] eq "" ) } { HTTP::redirect [ACCESS::session data get session.server.landinguri] }
} } - mikeshimkus_111Historic F5 Account
What auth method is Enterprise Vault set to use?
- Mark_II
When a user types in https://webmail.xyz.com/enterprisevault ( via f5 or TMG) the owa page appears and then enterprisevault.
I was going through the APM session and thought would give the below irule a shot
We got it working using the below on Outlook 2010 clients few delayed reconnection issues. However on Outlook 2013 we get page not found.
switch -glob [HTTP::uri] {
"/enterprisevault*" { if { not [string tolower [HTTP::header "User-Agent"]] contains "enterprisevault"} { pool EV_POOL }} } }
Is there a possible way where we could get this irule into the MS_Exchange_2007_apm_combined_pool_irule7 ?
Also when users connect via outlook client an NTLM authentication popup appears (which is normal) after the user enters the username and password.
a) We can see a session on APM as connected with the userid.
however the user has to repeat this by closing and re-opening the outlook client 2-3 times to get connected to exchange.
1) On the ASM logs which is currently in transparent I can only the RPC Uri / rpc.dll being requested
2) On APM Session details the User Agent was MSRPC.
Also did notice when the user was connecting via outlook 2013 we got the below header under APM session details
2015-02-10 15:42:27Received User-Agent header: Microsoft%20BITS%2f7.7.
Can we modify the iRule also to redirect based on User Agent ? Do you think this would help ? Do we have an integration guide with Symantec Enterprise Vault with F5 (LTM/APM/ASM) ?
Also please note we are using an iapp of exchange 2010 on exchange 2007 with modifications on APM.
First, ASM is incompatible with Outlook, so you should remove that policy from the virtual server, or deploy separate virtual servers for each service if you want to protect OWA and ActiveSync with ASM.
Including EV in the existing iRule would involve asking addtional questions that would lengthen both the iApp and deployment guide, which is something nobody wants. :-) I recommend using the iRule attacher in the iApp to get this done for now.
We don't have a guide for EV and I don't expect us to do one, unfortunately. You may want to consider involving F5's Professional Services here, especially since our Exchange solution is targeted at 2010 and 2013 only and you have a lot going on here with APM and ASM.
- Mark_II
Hi Mike,
ASM in transparent is only to see the logs will be on separate VS at a later stage.
The main show stopper is to get the EV working on outlook 2013 clients with APM.
Am sure missing something small in the iRule
