ryan_defeo_3162
Jul 06, 2017Enhanced key usage and machine cert auth
Is it possible to leverage machine cert authentication and have it read the enhanced key usage field within a certificate to determine resource allocation? I am sure there is a way to write an irule for this functionality, I just don't want it to get messy. Thanks!
You can retrieve the full certificate in a session variable : session.check_machinecert..cert.cert
You can find more info here.
Then you can parse the certificate using an irule or maybe with pure TCL in the VPE
Yann
