sdkarthik3591_2
Feb 05, 2016enable/disable at Node level and not pool level
Does anybody know or have code to enable and disable a server at node level(not pool level) in java using icontrol?
I don't think I've published any Java samples managing nodes, but you can take a look at this article on Pool Members. The code to enable/disable is pretty close and may help get you going.
-Joe
