yuanqiang_22112
May 22, 2016emerg logger:Re-starting logmysqld
Hello ereryone : VIPRIONC2400(V11.5.1、 hotfix10) with "LTM" 、“GTM”、“AFM”,now many logs display "emerg logger:Re-starting logmysqld"? Anynone have the same question ?
- Derek_Qiao_1388Historic F5 AccountTake a look your disk space with 'df -h'. Maybe you need to rebuild the AVR database. Recommend you log a support case for resolving it.
- yuanqiang_22112
3Q - Tikka_Nagi_1315Historic F5 Account
Without looking at the reason why mysql is constantly restarting it's difficult to say what's the root cause in this case. We have seen specific instances of this error where attempts to rename certain tables leads to this error. I would recommend that you open a support case and provide a qkview so that we can get to the root cause.
