Matt_Jannusch's avatar
Matt_Jannusch
Dec 18, 2013
Easy way to show universal persistence tables?
I've got some iRules that heavily utilize persist uie to store status values for objects, as well as custom persistence for user sessions. If I go into tmsh and run "show ltm persistence persist-records", I don't get back any universal persistence records even though I know there are active records in there.
Is there an easy way to dump all of the contents of the uie persist table and sub-tables so I can review what is stored there?
This is on 11.4.1HF1.
Thanks!
  • nathe's avatar
    nathe
    Matt,
    Have you just configured an iRule to do the persistence or have you also got a universal persistence profile applied to the VS too? I understand to see the persistence entries you need the profile too.
    Rgds,
    N
