Arik_Barzilay_6
Mar 19, 2009Dynamic ratio SNMPDCA issue warnings
Using LTM version 9.4.4-HF1,
I configured SNMPDCA profile with: Interval=5sec, Timeout=30sec, Version=v1, AgentType=Win2000; coefficients are CPU=1, Mem=0, Disk=0.
I use command "bigpipe node all dynamic ratio" to assert it works.
It seems to work fine, except for the warnings listed below, which appear at my Syslog every few menutes.
2009-03-19 09:19:49Local0.Error10.10.7.200Mar 19 09:21:33 load-balancer-2 mcpd[1738]: 01070533:3: evWrite finished with no byte sent to connection 0xa928370 (user %snmpdca) - connection deleted.
2009-03-19 09:26:49Local0.Error10.10.7.200Mar 19 09:28:33 load-balancer-2 mcpd[1738]: 01070533:3: evWrite finished with no byte sent to connection 0xa928370 (user %snmpdca) - connection deleted.
- hoolio
Hi Arik,
I haven't seen this error before and couldn't find any details on it on AskF5.com. You might try opening a case with F5 Support on this if you haven't already. If you do this and get more information, can you reply here for future reference?
Thanks,
Aaron
