purna_256577's avatar
purna_256577
Nov 20, 2017
Drive: /dev/sda filesystem type: Undetermined, when we perform SMART test disk have no issue.
We are getting below errors. When we perform the platform check we could see no disk issues. We see SMART test result are PASS. but still get the below errors, please let me know solution to stop those
warning pendsect[20702]: seek(1) error[25] recovery of LBA:226300793 not complete warning pendsect[20702]: Drive: /dev/sda filesystem type: Undetermined warning pendsect[20702]: File affected: NONE this behavior change ID 405839 mentioned in the KB @https://support.f5.com/csp/article/K14426
from the logs provided, Offline uncorrectable sectors were detected for below HD
Name Serial Device
HD1 WD-WMAYP1441913 /dev/sda
When we perform the platform check we could see no disk issues, please monitor the error logs, if still persist we may need to reboot the device to clear the alerts to popup.
[root@d4lc1:Active:Changes Pending] config platform_check Disk Tests SMART (/dev/sda): PASS
Hardware Acceleration Tests SSL (02:00.0): NOT RUN Test cannot run while the system is active, "bigstart stop" required. Miscellaneous Tests PCI: PASS Overall Platform Health: PASS - 1 test not run
Nov 17 16:08:50 INFO Test Complete: SMART (/dev/sda): PASS Nov 17 16:08:50 INFO Test Suite Complete: Disk Tests: PASS Nov 17 16:08:50 INFO Test Suite Begin: Hardware Acceleration Tests - 1 tests Nov 17 16:08:50 INFO Test Begin: SSL (02:00.0) Nov 17 16:08:50 DEBUG daemons_are_running: ['bigstart', 'status'] Nov 17 16:08:51 INFO Test Complete: SSL (02:00.0): NOT RUN - Test cannot run while the system is active, "bigstart stop" required. Nov 17 16:08:51 INFO Test Suite Complete: Hardware Acceleration Tests: PASS Nov 17 16:08:51 INFO Test Suite Begin: Miscellaneous Tests - 1 tests Nov 17 16:08:51 INFO Test Begin: PCI Nov 17 16:08:51 DEBUG Parsing golden PCI data from C102pci.golden Nov 17 16:08:51 DEBUG pci_devices: lspci -n Nov 17 16:08:51 INFO Test Complete: PCI: PASS Nov 17 16:08:51 INFO Test Suite Complete: Miscellaneous Tests: PASS Nov 17 16:08:51 INFO Run Complete, Overall Platform Health: PASS
