mariogolf_57851's avatar
mariogolf_57851
Oct 29, 2009
Does pycontrol work in Linux?
Looks strange:
!/bin/env python
Also:
PATH for PYTHON
ImportError: No module named pycontrol.pyControl
Tried this...
import sys
sys.path.append("/home/user/pycontrol")
  • yep, I have it running on ubuntu 9.04. I do have a 2.5 installation though 'cause I have issues with the ZSI library on 2.6. I'll go through the install steps again in the morning and write them down, but basically, if you install python2.5, and then the easy setup package, the zsi library, and the pyControl egg from your 2.5 python, you should be good to go.
  • The staza !/bin/env python is supposed to find the python executable on your system. It's a fairly common way to try and find an executable on without knowing the specific path (/bin/, /usr/bin/, /user/local/bin, etc.).
    Pycontrol works on Linux, although you'll need sudo if you're tying to install it via easy_install...
    -Matt
