ERLomboy_27803
Jan 21, 2016Does Lowering Priority help in draining connections for maintenance?
Hi Guys,
Was wondering if lowering priority in one pool member actually helps drain it's connections so we can take it out of the pool for maintenance?
Is it better to just force the conn...
kroestel_129077
Jan 22, 2016Historic F5 Account
Yes, it is better to offline the member. Also you are correct, if you have idle connection to the servers from clients even with the pool members offline those connection will remain open until the connections timeout or the server/client issues a close/rst to the connections.
