James_Yang_9981's avatar
James_Yang_9981
Sep 18, 2006
Does IBM MQ loadbalance is possible?
IBM MQ Server to Server use long live TCP connections. if just do simple load balancing, it may not actually load "balance" the traffic. customer require a loadbalancer that can recogonize the message in long live TCP connection and send to correct server with seperate message. Does anyone think about this? or if it's possible to write a rules to do that?
MQ using Asnychronize communication between two server.sending message an receiving messge is from diffrent TCP connection. In my opinion, it's possible to seperate the message but it will be hard to handle the session key of two server.
anyone have good idea? if it's possible, I will start to do it.
